Topic: AOD - C4 swap, lengths? (Read 5647 times) previous topic - next topic
Are these transmissions the same length?  wondering if I need to be concerned about fitting issues.
if you did a two second search, or read two threads below this one.
Two threads below this is about a C5, not a C4.  I understand it is a beefier C4, but from your picture we can see the C5 isn't listed, thus this post has more relevancy in my thread anyay :]
EDIT:  I wonder if the 3" difference is a cause for concern.  I'm sure it is, lol.  Dealing with it will be interesting...new longer shaft perhaps?
Hah, never mind, after reading that entire thingy Isee they're virtually the same length.  That's pretty odd considering how much bulkier the AOD is.
I did a C4 swap in 2004 after eating my 2nd AOD and it was really easy. The crossmember will need to be modified or using one from a T-5 mustang solves the issue. Everything else is good.
How did you modify it?  just hog the slots out further?  Pix would be amazing, gonna search a bit and see if i can find an article on it
Quote from: Grumbles;270858
The setback on the cross-member is set by ford . The "tubes" that position the x-member are welded to the x-member to hold it into place. Grinding the welds and positioning the x-member in place with your C4 is best. Then just reweld the tubes. Easy as 1-2-3 when you look at the x-member. Sorry no pics cause the car is 9000 miles away.
Hmmm.  I'm not entirely sure I understand.  The crossmember in my T-Bird looks like it was designed to accept multiple different length transmissions.  let me show you what I mean.
It has slots that allow the mount to be like 2" in difference.  Make sense?  What are you telling me I should do?  Will the transmission not fit into this slot?
The elongated holes might not be enough.  Most people shift the position of the mount.
X
Remove.
Grind the welds.
Install.
Shift the mount into the desired position and tac.
Remove, Re-weld, re-install.
but with a completely custom drivetrain, locating the C4 is more difficult.  So my question is this:  How far does the piece slide?  I'll be doing this before I even install my C4.  Because I need the C4 to locate the engine. 2 11/16" ?
1987 TC
I would probably Locate your engine where it will fit/clear the radiator and be relatively above the engine mounts.  Then position your C4.  Just my $0.02.
Just measure the bracket.  it will slide about the full travel of the tubes.  Leave it loose (un-welded) till you have your engine where you like it.
THose diagrams were extremely helpful. thanks :]
Quote from: danzajax;271102
I could leave it loose, I s'pose, thanks.  I have to make my own motor mounts, thus the issue.  So far I have it closely located, but thought I could verify them with the C4 located correctly.  oh well.
1987 TC
I can measure my T5 bracket.  It should be in about the same place as for a c4.  Let me know if you want the measurement.
-dz
That would be helpful.  Thanks in advance :]
