Topic: limiting (Read 1431 times) previous topic - next topic
limiting
Can the amount of turn be limited to keep the wheels from rubbing on the arms?
limiting
on a fully functional car... or youre build car????  is this the "slipping" sound i hear/feel when i turn the wheel all the way to do a u turn?????? Just getting a little more insight.... good question jerry!!!
[/IMG]
Just enjoyin the ride!!!!
limiting
On the vert. It has 40s on it and the fronts just catch the arms when the wheels are turned all the way.
limiting
not really,  your stuck with it and most people just dont turn all the way.  The only time you run into that is from a parking position and need out.  Turning all the way is hell on the P/S pump anyway.
While laid off, i kept up by doing car work in the garage.  The guy had the same problem as you. I explained it the same way and he said,, but I still dont want it rubbing anywhere.
My solution, I welded nut on the A arm that was in the perfect spot so when the rim came around, the rim contacted the nut which allowed room for the tire to not make contact.  I just poped the outter rods out and unlocked the steerng wheel so i could move everything easy to mic out where the nut would go on each side.
just a idea.
limiting
YES YOU CAN !!!! Go to Ford,pick up a pack of steering rack limiters.They are plastic discs that snap on to the inner tie rods and act as stops to limit the travel of the steering rack.Genuine Ford parts,and fairly cheap.That's exactly what they are made for.They will probably have to be ordered,but that's not an issue.
limiting
Like this?
http://www.lastcallracing.com/ford-steering-rack-limiters-n804842-s.html
limiting
And here's an install guide.
http://www.ffcobra.com/forums/showthread.php?t=206391&highlight=steering+rack+limiters
Thanks Vin
limiting
Taa-Daaa !!!!!!!!!!!  Just like magic.LOL.
limiting
Quote from: jcassity;270298
so now the nut will rub/se/gouge into the rim?
limiting
Glad I got the y3k Cobra arms as they let my 17x9's clear.
