Topic: 2 rear sway bars (Read 820 times) previous topic - next topic
2 rear sway bars
One's from The Sport, the other is from the '89 5.0 Stang that I got my parts from.
10 bucks each, does not include shipping.
Everything located in Laclede, Missouri.
2 rear sway bars
I still have these...one has the bolts, the other doesn't...if there's interest in both of them, I'll get bolts for the one...
2 rear sway bars
what is the thickness of them please
2 rear sway bars
The Sport sway bar should be the same part as the Turbo Coupe.
2 rear sway bars
i never knew its thickness  could you tell me vinnie  how thick s the Turbo coupe rear bar and front as well
thanx for the info
2 rear sway bars
I really don't remember.I know the front bar is thicker than my friend's aftermarket bar,and the rear is thicker than the stock (standard) sway bar.Not a lot to go by,but,the Sport sway bars can help you if you have the skinny standard sway bar.
2 rear sway bars
'87-'88 TC and Sport FRONT swaybars are 1 5/16" thickness, while the rear bars for the same cars are 7/8"
One of the bars is from my '88 TC, the other is from an '89 Stang GT vert. Both are the same thickness, but are shaped slightly different, but they WILL both work on Thunderbird/Cougar.
If you need pics, just let me know. :D
2 rear sway bars
you have PM
