Topic: SO.... this isnt good I would imagine.... (Read 1595 times) previous topic - next topic
Did I kill this T5 or what?
LOL I Drove it for 6 months with a blown 3rd gear.  when you tilt it back and forth it sounds like a baby rattle, LOL.
Yep it's likely junk(or to define, a bigger piece of junk than one that has still has 3rd)... When 3rd goes, you are talking broken cluster gear, no doubt the smaller pieces have been crunched up in the other gears and bearings... End result is about the same as if you'd loaded it up with sand...
hahah you should see the little amout of fuild that came out...(been leaking for awhile and havent topped it up) was mostly powdered metal pieces. LMAO...
Yikes, thats horrible!
It sounds like when you pull start a gas-powered weed whacker! :rollin:
OWWWWWWWWWWWWW.
Yea she's done.
Put some Lucas in it and call 'er good! ;) j/k!
Sounds like on of those kid toys...you push around, and the little balls pop around inside the clear plastic dome..:rollin:
Well got the new tranny in and took her for a test rip.
you aren't using the stock shifter are you.....:poke:
~John~
Quote from: shame302;269242
Yeah for now, thats Why I wasnt power shifting...
Tomorrow I am changing the Driveshaft yoke and U joints as the tranny was viberating so bad it wore a pretty big grove out of the yoke and wrecked the joints.
So we can count on another vid then
~John~
sure, especially after I install the Line Lock next weekend... ;)  But it will look/sound better from the outside in that vid....
