Topic: HO cam vs F150 cam (Read 1644 times) previous topic - next topic
HO cam vs F150 cam
I have a 96 5.0 roller E7's and I am unsure of which cam to use to make the most torque/power I asked a few questions on the small block forum but nobody seemed to know anything.  this engine will be carbed with an edelbrock performer intake and a 1406 carb with long tube hooker competition headers.  ideas and opinions welcome
HO cam vs F150 cam
That cam has the same exhaust duration as the HO cam, but 20* less intake duration...it's the same cam that's in the Explorers and their peak power is *claimed* to happen around 4200 with "P" heads.
If you're using stock E7 heads, it may fall off a little sooner than 4200.
Good luck,
Don
HO cam vs F150 cam
This should help....
HO cam vs F150 cam
If you have both cams I'd stick the HO one in ;)
HO cam vs F150 cam
I will have both cams by the end of the week and I am leaning more toward the HO cam.  too bad I'm not putting this in my TC :( should be alright in the cougar I hope.
HO cam vs F150 cam
Great info, too bad I dont know how to make heads or tails of it.
Mike
