Topic: What to do about drivers window falling forward as it's lowered? (Read 1058 times) previous topic - next topic
What is the fix for a window falling forward as the window is lowered? What is the BEST method to remove the door panel? I had an 85 bird once and had to basically disassemble everything on the door and busting the armrest plastic in the process.
Well, what year?
Sorry 88 Bird Sport Coupe. Just trying to fix all my small issues before I start driving it.
Fixed:
Tail Light Separation
BO/O switch (thanks!)
Need to Fix:
busted windshield
drivers window
brakes (upgrading to 11" this week)
I had this problem - the front clip was still holding the window but the rear of the window had its sleeve that it slides in messed up. The fix: pull the door panel off, push the sleeve back up where it belongs, and put new adhesive on the rear window clip.
1988 Thunderbird Sport
if it came off of the forward clip, make sure when you put it together you use a good adhesive.  I think I've had my door panel of at least 3 times to fix this in the past few years.  Last fix lasted about 2 years so far.
