Topic: Current draw (Read 3813 times) previous topic - next topic
Current draw
Ok, I know the car draws around 50 mA just sitting there, right?  Is that just for the radio, or for the computer too.  I had a .14 Amp draw on it, and as soon as a pulled the radio (aftermarket, if that makes a difference), the draw went away.... totally.  Meter reads 0.  I'm thought the computer would draw some too, right?
351W in the works
Quote from: bhazard;300566
You got woman'd.
Current draw
50ma is the upper limit, all I've checked have been less than 25ma... I too would have thought the EEC would draw a bit of current as well, but maybe not... If it's not giving a memory fail code (15 I believe), I wouldn't be concerned...
Current draw
I'm trying to start a fresh engine, and I've gone mass air.  The engine will turn, but not fire, and I'm getting spark.  Thought the injectors weren't firing, but couldn't test it till I found the drain.  Was hoping I got two birds with one stone, but the noid light is going off now, so back to square one....
351W in the works
You got woman'd.
Current draw
anytime i see spark and fuel but no start,, tells me the stator is bad down in the distributor.
This has only happened to me twice though were I had the time to troubleshoot.
Current draw
It was the radio.  Always acted funny anyway, turning off magically.
351W in the works
You got woman'd.
Current draw
Radio kept the car from starting? ;)
Seriously, did you solve it?
Current draw
Radio killed battery.  Which kinda killed the car. :P
Solved draw problem, but injectors still not working.  Was going to test fuel pressure, but now the d@$n fuel pump ain't working....
If this car was a woman, I'd ask for a divorce.
351W in the works
You got woman'd.
Current draw
Quote from: tireshredder;268523
injectors still not working. Now the d@$n fuel pump ain't working....
;) :d
Current draw
Probably your problem from the begnning...
Current draw
It was priming fine until I went to test the pressure.  It's a new Walbro unit too. My brother and I think the relay went bad, cause the wire from it to the pump isn't getting power.  But it's just an guess for the most part.
351W in the works
You got woman'd.
Current draw
Did you try resetting the inertia switch???
Current draw
Of course.  New relay didn't work either.  I'm trying to find a wiring diagram for the fuel pump system so I can start testing (and know what I'm doing).
How many volts can the pump handle?  I want to test it, to see if that is the problem.
351W in the works
You got woman'd.
Current draw
Ok, I've been back at it.  Inertia switch is fine.  If I jump the power wire to the fuel pump wire on the relay connector, it runs.  If I bypass the inertia switch, it doesn't.  I thinking now that the relay isn't getting the signal, so it's not switching on.  Anyone have an idea?
351W in the works
You got woman'd.
Current draw
Ok, tested a couple wires on the connector from them to the ground.  Red wire -12V.  Yellow Wire-12V.  Tan/Green- 12V.  Pink/black- 0V.  I think thats right, but I've been wrong before.
And as a side note, the new relay has 5 connectors, but the old one only has 4.  It's the right part number (from the website anyway.)  Could this be messing it up?
351W in the works
You got woman'd.
Current draw
Put the old fuel pump relay back in. The new one having an extra connector is suspicious.
With the key in run without starting the pump should run for 1 or 2 seconds (priming).
If it does not run leave the key in run and jumper the T/LG wire in pin 6 of the self test connector to ground.
If the pump runs it means the EEC Power Relay, the Inertia Switch and the Fuel Pump Relay
 are all good but EEC did not provide ground for the pump relay when it was supposed to
prime.
BK/Y wire #175 and R wire #361 are tied together on the next page.
