Topic: need help.. (Read 1802 times) previous topic - next topic
need help..
Trying to figure out what color my car was orignal from the factory, The door sticker i cant read, but i managed to find this plate in the glove box, im not really sure what it is, other then the fact that it has the vin on it,
anybody know?
my car looks to be medium canyon red, but
i dont really know for sure, considering it had a black paint job years ago....
http://img.photobucket.com/albums/v226/ChrisPerry9/CIMG0159.jpg
i also posted this at nato
need help..
Almost looks like the vin plate thats under the windshield........
FOXLESS!!
1994 Lincoln Mark VIII
need help..
That tag would have been on the original owner warranty card. Look on the upper rad tie bar and see if your tag is still there
need help..
2U was med red metallic in 83
need help..
well that would make sense, seeing as the red has some metallic in it.
Thanks guys! and as for the rad tag, i believe its long gone.
need help..
take out a bolt that holds the fender on, or door hinge bolt.
Somewhere on your car you will find the original color.
You should also find the original color by taking an interior panel off too. most likely a back side panel, or the one under the dash at the door/ rocker area.
need help..
I almost forgot that there was someone that lived that close to me.
We could almost put together a PA/ NY meet up now.
need help..
ya we could haha, i guess my guess is red metallic. ill find out saturday 2U i would imagine is the paint code.
need help..
Quote from: Dansbirds;267666
2U is the paint code, so assuming Dan gave accurate info for the paint, that is correct...
That metal plate is from the warranty card... Glue dries out, they fall off...
BD is the interior trim code(color and style), 03L(Nov 3) is the "scheduled" build date(doesn't mean it was actually built on that day, but will be close)... Last two are transmission and rear axle code, unfortunately I don't have any info to decode that for the '83s...
need help..
well thanks for the help guys, ordered the paint today :) and finally started a little bit of body work, thankfully the car is solid. But i wanted to get rid of the antenna, and passenger doorlock.
http://img.photobucket.com/albums/v226/ChrisPerry9/CIMG0141.jpg
That was a few weeks ago.
today i did some body work, with my uncle, hes teaching me.
i primed it and rattle can blacked it for now, just to keep it safe, because the car wont be fully painted til about june.
http://img.photobucket.com/albums/v226/ChrisPerry9/CIMG0169.jpg
http://img.photobucket.com/albums/v226/ChrisPerry9/CIMG0168.jpg
need help..
i guess i need to get a right front fender, if possible, mines pretty screwed up.
any body have one?
need help..
That's too bad. It looked pretty good in the picture. Well, the ex antenna hole looked good anyway. It does look messed up along the door opening, but not bad enough to replace? Either way, try a "Wanted" ad and see what you can find. Good luck!
1987 Turbo Coupe - Son's car
1934 Ford - My project car
