Topic: Has anyone on this Fourm Done an LS1 swap into there Bird (Read 21997 times) previous topic - next topic
OK I recently came accross a very cheep LS1 from a family member and have read about all the mustang LS1 swaps and was wondering if anyone here has done this on a bird. OK Let the flam beggin.
87 TC
Well I for one think this would be neat. They are pretty strong motors and take well to mods. If you could get it to work I think you'd have the first LS1 powered Fox Bird/Cat. Go for it, theres nothing like a guy that blazes his own trail.
Please do, but do it to a V6. :hick:
Go for it man...LS1's are amazing motors.  I have seen fox mustang's in person with LS1's and they actually look like a pretty tight fit in there.  I think I might have a pic somewhere of one I'll dig it up.
Only problem i have with it is droppin' a chevy in a ford.
[SIGPIC][/SIGPIC]:burnout: :flame:
1987 Cougar LS w/460big block & AOD tranny
1992 Cougar XR7 Supercharged 3.8L V6
1987 Pontiac Firebird w/3.1 V6
1981 AMC Eagle SX/4
1988 AMC Eagle Wagon w/14000 mile crate 258 I-6
1931 Model A Pickup
Here are some pics of a nice Chevrolet-motored fox 'Stang I saw on Power Tour last year.  It really caught me off guard, I just kind of glanced at it totally assuming a blown 5.0.  After looking at these pictures, I guess my memory was a little off...It wasnt that tight in there after all.  Hell people put big blocks into Foxes so an LS1 should not be a problem fitment wise.  I'd about bet a 4.6 is wider than an LS1.
that thing sounds nasty. sounds like one helluva job, but too awesome to not do. i second the use of a v6 car.
I helped put a V-6 Turbo Buick in a Fox Mustang back in 2000...you want to talk about no camp to hang with....WOW!!
I say have at it. It can't be hard since the Deck height of a LS motor is not far off the 351W. The fox body is a great swap platform and it's light weight compared to a heavy LS1 camaro or GTO. Those cars were closer to 4000 lbs than 3000 lbs and still run in the 12's with a few bolt ons.
Sounds like a worthy project.
saw a LSx swapped fox mustang yesterday with a single turbo. one of the best uses of a fox mustang i have seen in a long time...
If I had a Chevy engine I would put it in a GM vehicle. Why not just put it in a S-10 like everyone else does ????
Lets see... the Ford guys will walk away after seeing that LS  and the GM guys will wonder why you drive a Ford.
Too many Ford engine combos out there for me to ever consider building a cross-breed. JMO
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Quote from: 83-88T-Bird Guy;267746
I agree, and the LS series of motors are more expensive to hop up then a 302...
Quote from: 1WLD BRD;267749
True enough, but with an LSx you're starting off at a baseline that would already cost you a pretty penny to achieve on a 302. You're looking at aftermarket heads, intake, and cam, along with the attendant upgrades required (larger injectors, bigger TB & MAF, etc) just to get the 302 over 300 horses. The LS1 starts at what, 305 horses? Plus you're getting a lighter engine (all aluminum, unless you go with a truck engine) and stronger, too.
If I could find a wrecked LSx/6-speed donor car I'd swap it into my T-Bird in a heartbeat (no pun intended).
Ford should have offered something similar, instead of only a 281 cu in OHC thingy... Sure we have a 40 year old 351(basic design back to '60) but of course it has to be built up same as a 5.0... I got no problem with it, even if it were in a TC...
The only real problem with the swap is the lack of respect you would get with it. If you are the type of person who cares what other people think, it probably isn't the way to go. Certainly don't do it thinking people in general will think its awesome. Id be willing to wager it would be received even less well than modding something obscure like a fox tbird/cougar let alone modding one with a  GM engine. I would never do it because i don't care for it myself. Id rather stuff a modular mach1 4 valve into it.
~John~
