Topic: 7.5" Mark Rear worth it? (Read 1679 times) previous topic - next topic
Guy wants to trade me a 7.5" disk from an 85 LSC for the 65 Stang grill I have. Worth it?
Here is the question though. I was planning on swapping to 31 spline 3rd member and axles IF I can get them in the right length. Havent read too far into it yet. Could I do the same with the 7.5?
I would think I could use the axles from the 8.8", but what about 3rd member, Is there a 7.5" that came with 31? If not then that is out.
The 7.5" gets a bad rap most of the time. From what I read if they are built right they can handle some power. But is it worth it? I would literary have no money in the trade so the only money would be in the rebuild. Would it be worth it?
I would be going 3.73 with trac loc. Would do a girdle too.
I dont see it worth just the brake set up or I would swap it all to an 8.8". But since I would be doing 31s on a 8.8 the the only thing I could use it the brakes.
What do you guys think? I already know that most people dont believe in the 7.5", got it. But experience with a build 7.5 would help. I read over most of the sticky which did help, but is it worth the trade?
I think in the end you are going to want an 8.8 but really its up to you. I always thought all LSC Mark VII's had 8.8's but I guess not. Hold out for an 8.8. Thats what I think.
Quote from: 86XR7project;267569
Years is what comes into play.
I would still hold out for an 8.8 if I were you. I just think that you'll be happy you did someday.
just get the rear, if you need one. The 7.5 lasted for over 22 years so far.
Quote from: Haystack;267701
Got 23 on mine. My abuse, 85k, and the whole 150 HP my car has. I want to swap something that is goin to hold a little power when I can build a motor
84-85 Mark VIIs still had the 7.5 axle. It would probably be ok for now, but if you plan on doing any mods then hold out for a 8.8"
Matt
I don't think any 7.5 ever had 31 spline axles, be like shooting sparrows with a 30.06...
Unless you're going to five lug, the 28 spline axles should be fine... Been running the originals in my TC for almost 10 years with the 5.0, no issue...
Quote from: TurboCoupe50;267912
Yeah, thats the plan. That is why I am looking at a Mark rear. Only reason I threw around the idea of 31s is it is possible and cheap with the 8.8 using Explorer stuff. Will I ever need it? Who knows. One of those do it right the first time things since it is one of the things I dont have to rush. Another because I can things too. Usually dont play out that good though on the budgets I set(manual steering)
