Topic: 295/50-15 (Read 1477 times) previous topic - next topic
295/50-15
anyone have pics or have any advice on 295/50's on a bird? i do not mind rolling the fender lip if needed and would like to keep my quad shocks, is this possible?
86 Mustang GT
295/50-15
Quote from: Dougy_Fresh;267018
i heard the quad shocks isn't necessary if your diff ratio is better than 2.73
for gettin your rearend stiffer your better to put an aftermarket lower and upper arm or weld a plate under your stock ones
295/50-15
i'm actually planning to build some lower control arms when i start making real power
86 Mustang GT
295/50-15
Quote from: akh43;267033
no the quad shocks are needed regardless of your gear ratio, once you replace your control arms with nice stiff pieces then you can ditch the quads.
295/50-15
The quads band-aid a bad design.
You'll probably need to flare the fronts.  Mustang guys often put 315s out back.
__________________
Twin '85 TCs
White/ Grey 2-tone
