Topic: Subaru turbo (Read 2224 times) previous topic - next topic
Subaru turbo
almost positive that subies use IHI turbos but I dunno about the
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Subaru turbo
Any idea if they are bigger or smaller than the rhb52?
1988 Thunderbird Turbo Coupe
Subaru turbo
That sure LOOKS like a tiny compressor housing.
Subaru turbo
look at the car it's from..300HP stock.  It's gotta be a decent one. I may take my spare exhaust and match it up.
Subaru turbo
That doesn't mean squat.
Waste your money if you like I guess...
Subaru turbo
Thats an odd way to look at it. By the reasoning if a lugnut comes from a 550Hp Ford GT it MUST be good, right?
Subaru turbo
Quote from: lakenheath24;266933
I have a feeling that the total engine design has a lot to do with the output on the Subaru motor.
Turbocharged
2.5L boxer DOHC, 4 cylinder, 16 valves
Dual active valve control system
Sequential multi-port fuel injection
Alum alloy intake manifold
Cast-iron exhaust manifolds
Reinforced cast aluminum block, cast iron cylinder liners,  semi-closed deck design, five main bearings.
Bore: 99.5x79mm, 3.92x3.11
Hood scoop air intake intercooler
6700 RPM redline
Horsepower:  305hp@6000rpm,
Torque:  ft lbs 290@4000rpm
Read this thread:  http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/77186-ihi-turbo-worthwile-upgrade.html
Subaru turbo
Exactly! larger engine, DOHC, and the overall newer technology makes the 300hp not the turbo alone.
If you put that turbo on a 2.3 you might gain a little, but nowhere near if you put a t3, t3/t4 or HX35 on there. I would recommend you save up a bit and get a larger turbo.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Subaru turbo
The 2.3 motor is pretty good on it's own as well....the turbo makes it even better...that's the way I was looking at it.  Hence why I was wondering what the specs on it were, before i "wasted" my money as someone so eloquently put it.
Subaru turbo
Hate to say it like this but maybe if you want to know about the SUBARU turbo you should ask SUBARU enthusiasts? Just a wayward thought.
Subaru turbo
Quote from: lakenheath24;267188
The 2.3 puts out around 100-110hp NA in stock form on a good day.  The addition of the turbo effectively doubled that in it's max factory trim.  The stock 2.3 head flows for , even ported they don't flow near what most modern heads do.  The 2.3T's had a pretty big turbo on them for the time and displacement because they were trying to cram a lot of air into them to get them to make power to overcome the poor-flowing design of the motor.  Had it flowed better, it would have required less turbo.  The T3's on the Ford 2.3T's are an "upgrade" to many of the other turbo cars of the time, such as the Volvos and Saabs. Hell, the turbo on my Volvo turbo is tiny compared to the stock .60/.63 T3's on the Fords.  Even at that, it put out the same power as the Fords even with a smaller displacement, smaller turbo and less boost...  Why?  A better flowing head.  I'm not talking about the 16V one folks are using as a conversion these days though. Even the 8V Volvo head is an "upgrade" over the Ford one in regards to flow.
That turbo is a small turbo to boost an already well-flowing.  They don't need to hang a big turbo on it to get the power.
Just because the Subie engine makes 300hp with that turbo, doesn't mean the 2.3T will.
It's a small turbo and a waste of your money (yes, I said it again).
A T3/T4 or a Holset is your choice for the 2.3T, not a turbo smaller than what you have already.
Subaru turbo
Gotcha Chuck, that's why my original post asked what the specs were, not to compare apple motors to orange motors. You never know when something of the wall, like a subaru turbo, might be a perfect fit.
