Topic: window rubber seal thing (Read 1369 times) previous topic - next topic
i don't know what it is called.  it is on the outside of the door glass and makes contact with the glass keeping water from running into the door.    it has a corresponding piece on the inside.  both pieces together "pinch" the window.  mine are dry rotted and cracked on the exterior pieces.    at the dealer the counter guy chuckled and said "no way you can't get THOSE kind of parts" anymore.    where can i get this piece?  how do i take it off?    my gut tells me to take the interior panels off to check for rust on the sheet metal....but i'm not sure how to get that off either without breaking it.  thanks
first things first,
what kinda car you got? year?
first things first,
its an 86 cougar---  but i found my answer in a sub section of this section (assembly/disassembly).  style 43 weather stripping from JC whitney is what i need and CougarCragar has an excellent post about installation.      http://www.foxtbirdcougarforums.com/showthread.php?t=8969
And that's where I would have sent you. :D
I believe they are called Dew Wipes.
