Topic: car leaning (Read 2360 times) previous topic - next topic
car leaning
Ive noticed the past few days my car sits lower on the drivers side rear.  I measured up to the fender lip from the ground.
drivers  side  is  27.5 inches
passenger side is 28.25 inches
I havent changed anything?
Mike
car leaning
broken spring?
car leaning
Enjoy the fox body lean.
Normal on older foxes,you still may have a broken spring but it will never be level lol.
car leaning
I had a broken spring on the pass side front of my car. Still seemed to sit higher on that side though.
I vote broke spring. You wont know til you try and fix it.
car leaning
car leaning
maybe you need to lay of the cheeseburgers.:D
car leaning
Quote from: lakenheath24;266565
MMMM! Cheeseburger sounds really good right now....
car leaning
I'd suspect a broken spring on the front left corner. A broken spring there will bring the left rear down and raise the right rear slightly. These cars are well known for breaking front springs...
car leaning
join the club :D:punchballs:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
car leaning
Quote from: Thunder Chicken;266578
What about rears breaking? My pass side front was broke but my car was lower on driver rear.
car leaning
maybe you need to lay off the cheeseburgers.:D
That is true.
So the front spring broken cause the rear to raise?  I never would have guessed that.
Can you still get springs from Ford, what do you guys use?
Mike
car leaning
Quote from: 347Thunder;266579
That looks about like mine, but reversed. LOL
Mike
car leaning
I've got all new springs and shocks all the way around on mine...and it still leans to the driver's side slightly. I don't know what causes this, although it is pretty common on a fox.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
car leaning
Quote from: 88BlueBird;266585
Random guess but since we all know how ridged our cars are not my guess is frame tweak. The wear of the driver weight to one side, 20+ years of wear. Causing a sag to one side.
car leaning
It wasnt leaning like this till just a few days ago, now it is pr0nounced.
I found some MOOG standard susp. part number 8658 ?
Ill prob just wait till I put 11" brakes on the front along with new struts, then swap the springs at that time.
Mike
