Topic: Does the 88 T-bird share the same front control arm with Mustang? (Read 1105 times) previous topic - next topic
Does the 88 T-bird share the same front control arm with Mustang? EDIT: Ok i see in the tech area that 94-98 mustang control arms work on the 88's. What would it matter if I swapped in a 91 mustang Gt rack, tie rods, and control arms? I'd be using the spindles and all off the GT as well.
You'll be pulling the front wheels in 3/4" per side...that's what would matter.
So 94-98 mustang control arms and the rest of the GT parts will swap in fine correct?
Yes, if you use Fox ball joints in the SN-95 arms.
I have a used set of SN-95 arms (w/o ball joints) I'd let go cheap.  PM me if interested.
