Topic: rotor type (Read 1135 times) previous topic - next topic
rotor type
would an 86 turbo coupe have a push on or screw on rotor?
thanks
dan
84 TC - under contruction
2018 F150 2.7 4x4 STX
98 F-150 XLT - 4.6, auto, 4x4, extended cab
rotor type
That is sorta a divided year you could have either. If it is an early production then it should have the screw on type if it was late production is should have the push on. That is assuming that the Dizzy has never been changed. Then it could be either way. But the safest way would be to get up remove two screws and make sure.
rotor type
Quote from: ipsd;266248
This
