Topic: Rear window trim clips wanted (Read 1144 times) previous topic - next topic
Like the title says, I need some of the clips to hold the rear window trim on my '88 Bird. I've checked glass places and they're obsolete. I don't have a pic of a good one but these are about 1.25" long and 3/8" wide and mount on little studs on the body of the car, then the trim clips onto them. I need about 10. A former member was supposed to send me some years ago but they never came, and I didn't press it because trim was down on my list of priorities. Now it's back near the top. Any of you southern guys have a parts T-Bird lying around with these clips?
Body shop got a box of 'em when my car was painted - I'll look for them when I get home. One of the above is too square looking and I can't find the part on the other site (I know what they should look like from memory).
This may be what you need, showing still available.
Dorman #700-405
Ivygreen and Kitz Cat: Those are the windshield clips. I've got a bunch of those, it's the rear window clips I need.
I might have some from an '87 XR7 Cougar.  Buried in my Tbird room somewhere, though.
1987 TC
That should be the clips that hold the molding on. At least that's what I thought.
Kitz: It is the clip that holds the windshield moulding on. The rear window moulding clips are different. They're about 1.25-1.5" long and about 3/8" tall. If I still had a good one I'd take a pic.
Now, keep in mind this is a T-Bird. Cougars might use the same clips front and rear.
rear clips are the thin ones. I'll see what I can do for you this afternoon
Here's what survived years of rusting from the parts bird. They're a little rusted still, but you can have them if you want. 6 are better then none.
Those are the ones I need. I'll send you a PM, Jerry
Back at you
TC, I'd still try Dorman.  I had to hunt down some shorter ones for the '83.  The ones I needed weren't as short as yours, but they were different from the fronts.
I emailed Dorman and got the part number and then got the parts from RockAuto
OK, I found the part number the auto body guy used for these clips:
J&T Automotive
P/N - 1412
`84 Ford Backlite
Moulding Clip
#E4ZB-6142413-AA
