Topic: Motors. (Read 912 times) previous topic - next topic
Motors.
Is the 1994-96 Ford Mustang V-6 exactly the same motor as a 1987-88 Thunderbird/Cougar motor? I'm unaware if there's very many differing intricacies..
If it is....what's the most inexpensive power adder outside of a cold air intake you can do to one of these motors? (inexpensive being...less than 300 dollars, let's say)
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
Motors.
Yes. It's the same engine, but has a more modern EEC-V computer with Mass Air.
Best bang for the buck would be true duel exhaust system..but its only going to give you maybe 10hp, and thats if you remove the catalytic converters.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Motors.
The 87 T-Bird V6 is significantly different than the 88 V6. The 87 has CFI and tin valve covers (the tops of the heads are shaped differently), and the block is not machined for a balance shaft.
There are some minor differences between the 88 and the 89 and newer engines as well, but for all intents and purposed a '94-'95 would be a drop-in affair. Accessory and bracket mounting may be different between the T-Bird and Mustang engines.
Motors.
Here you go.
http://www.babpen 15s.com/editorial/ar/ar90134.htm
Motors.
This is awesome. Thanks.
-'88 Tbird 3.8
