Topic: Wow (Read 2161 times) previous topic - next topic
Wow
Hi everyone and I want to thank you all for your input, it has given me alot to go on as well a lot of work which I love to do to my Cougar. I have a persitent problem I have put all new parts into her by the way even a new ECM. Okay I'll being cruisin and then all of a sudden my whole electrical system; lights, stereo blink off, it is only a seconds time span but wow it is enough to get me worried. I have followed all my grounds they are good and I am at a stand still as to finding what would cause this to happen. Could it be my switch for my lights or maybe something in the electrical on the column? Because it seems to happen mostly when I have the lights on and get this one when I push the brakes or use the turn signal. I replaced the brake switch, I just don't know what is causing this.... HELP PLEASE This girl is at her wits end for sure now.  :rollin: Oh Yeah she is an 86, 3.8
Re: Wow
Check your ignition switch at the steering column. Could possibly be at the headlight switch ( pigtail or switch), but I would start at the ignition switch.
 :evilgrin:  :evilgrin:  :evilgrin:
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Re: Wow
i agree, ignition switch
Re: Wow
its the blinker fluid sensor/relay for sure. check that first. the circuit may be corrupt.
~John~
