Topic: wheel studs (Read 1081 times) previous topic - next topic
wheel studs
Does anyone know what the wheel stud knurl size is for the rotors on an 84
[SIGPIC][/SIGPIC]84 Thunderbird/ 408ci windsor, vic jr. heads,super victor intake/ camshaft ground by Cam Research/Pro Systems 950 cfm/msd ign./hooker super comp headers/Full manual C4, ultimate converter concepts 5000 stall/ 8.8 w/4.33 gears,Moser 35 spline axles and spool/double adjustable upper and lower control arms/Strange drag shocks and struts/10 point roll cage/weld drag lites/28 x10.5"/UPR k member and control arms/coil overs. 1/8 mile to date 6.39-60' 1.35 "NO POWER ADDERS"
wheel studs
no,, but just take one off and bring it to the parts store along with a good lug nut.
wheel studs
Quote from: jcassity;264590
i dont need a replace ment i have to have long studs  for drag racing. i bought some moroso studs but the knurl size is .615 (TO BIG) I believe  i need .563 knurl but thought i would ask to see if anyone knows for sure. I know some mustang racers drill out the rotors to accomodate the .615 knurl. I guess i could mic a replacement at the parts house.
wheel studs
yeah,, just a cone grinder / milling bit and go easy so you end up having to force them in.  You might also get away with using a stepper bit and stop at 1/2'', fine tune from there.
A long time ago, someone here replaced studs and everything was fine.  One day he posted a thread that he couldnt get his lug nuts off because the stud was spinning, and you know what that means.  You pretty much cant get the wheel off unless luck is on your side.
wheel studs
Quote from: jcassity;264704
You have to drill out the lugs or use a chisel set. It takes quite some time. I had it happen to me after a shop didn't tighten my lug nuts all the way. I spent over $100 on just drill bits before i started using the chisel set.
