Topic: loose steering column (Read 4383 times) previous topic - next topic
can a ford steering column be tightened up like a gm column? my column has a lot of play in it, not slop in the steering itself, i mean i can move the steering wheel about 2" side-side.
86 Mustang GT
Are you sure its the column and not the wheel itselt. I know my cars wheel almost came off when I was driving. Take the horn button and springs out, and make sure the bolt is tight.
no, i can watch the whole column move side to side, it moves where it tilts
86 Mustang GT
There are only 4 bolts that hold it in. Some bolt to the dash. If the dash is loose it could affect it.
might just swap the stang column in if i swap the dash.
86 Mustang GT
Pull the plastic covers off of the column,and on the friver side,there are two bolts that tend to loosen over the years.Pull one at a time,add a little loctite,and tighten them up.That should fix the problem.Once you pull the covers and wiggle the steering wheel,you'll see them.
Glad the question was posted!  I have one that does it too.  I'll have to pull the covers and check the bolts.  Thanks for the info!
Ditto.  I had mine apart awhile back, but didn't see the 4 bolts.  I just wedged something in there to tighten it up.  I'm gonna re-examine....
Thanks, vin.  You're a wealth of knowledge as usual.
===85BIRD===
:birdsmily:
i wouldn't say that.I just know what I've done myself,and help where I can.....and ask for help.....a lot.LOL.
Regardless, thanks for spreading your knowledge.  If you ever need anything just let me know... and I'll also chime in when I can.
===85BIRD===
:birdsmily:
Thanks a lot.We're all in it together.
You got that right.  I'm sure glad all-ya'll are out there too.  Before I found this site I just thought I was the only one that still loved my mid 80's 4-eye.
===85BIRD===
:birdsmily:
Quote from: 85bird;264902
I hear you. This is like my new home. I enjoy this site quite a bit, I may not have much useful to add but I enjoy it all the same.
Heck, you add just by being a part of this exclusive group of nuts.
===85BIRD===
:birdsmily:
Quote from: 86T-bird;264862
When my white coug did this, there were two torx bolts that were loose.
I finally got them to simmer down with some wood glue on the threads,,,,,,back when I was oh,, didnt have a pot to piss in so to speak.
loc-tite them.  I forget what T-x size they are but the loose part will be very obvious when the covers come off and you jiggle the wheel.
