Topic: Electric antenna harness. (Read 1252 times) previous topic - next topic
If weather permits I will be heading to my farovite automotive recyclers this weekend to scrounge some peices for my Cougar. I believe the donor has an electric antenna, my XR7 doesnt. As I will be harvesting the rt fender it will be quite easy to get the antenna as well as the switch. Is there a seperate harness for this or is it part of the dash harness. I got the dash last summer(only one I ever found not cracked) so the harness is very accessible.
I think your screwed in that catagory.  The last point of connection would be a connector behind the radio called C339 (grey conn with three terminals) leading out to the power antenna motor.
It makes no sense why the motor on the fender wouldnt have a connector so the EVTM page below may be wrong.
If the motor on your bone yard donor has a connector, then all you need to do is get the switch.  You can fab up a couple black leads easy enough, just flip the leads if down is up and up is down ect.
It is a separate harness, its not even that hard to get out.
