Topic: Oh AOD How I hate THEE ALSO!!! (Read 3652 times) previous topic - next topic
I just put a new engine in my car,but after doing this my aod acts like it has a stall converter in it. I shifted perfect before swap. i just had the cable adjusted where it worked awesome. So now wtf!!!
It has new filter fluid,and was clean when changed!!! Front pump or something being a bitch!! Help me please my people!!!!
P.S. 5spd swap i know!!!  :burnout:
1999 Trailblazer(wifes rig)
Dunno bud, I pretty much yanked the AOD and sold it quick.  Not willing to play with that POS
Maybe make sure your pressure is okay?
What do you mean by:
In normal everyday driving if everything is working properly; you will not notice a higher stall converter....
Its slips up to certain rpm then it takes off like a sob. Oh and OD worked perfect before and now nothing??
Maybe something has worked it's way loose? Wire chafed somewhere?
Is the TV cable still connected properly? You know how they fall apart. If it's still connected, is it and its linkage moving properly?
TV cable stuff aside, it sounds to me like you need a tranny. It's probably slipping in first gear, and takes off when it shifts into second.
Do a 5-speed swap and be done with it :hick:
See this is exactly why I'm contemplating a C4 or a T-5 (probably the latter of the two)
I got c-4 but want the overdrive!!!!
OD is definitely a big plus in a daily driver.  All you people encouraging T5 swap, I rise to remark some of us are incredibly lazy. :p
Im not lazy just broke!!!!  LOL!!!!!hahaha
Not to mention you can build a c4 to smoke the t-5 on the track. Expensive but crazy shifting. And we can still be lazy and let the girlfriend drive home from the bar.
Real cars have three pedals.
Mine has 3.....gas, brake, and e-brake:hick:
FOXLESS!!
1994 Lincoln Mark VIII
No, real cars go fast, dont lose boost from having to let off to shift, dont hit rev limiters or over rev while shifting because you stayed in it while pushing the clutch in. =)
the whole deal that its slipping, in general.  either it could be eased by a fluid change, but inevitably its going to croak.  infact i'd advise you to decide what transmission your ganna use, and get it ready for the swap within the next 3-6 months.  you definatly want to get rid of an AOD that slips.. even when you bring one back from death, it acts like what your describing right before it dies.
"get your affairs in order" so to speak.
