Topic: Tightening up... (Read 2540 times) previous topic - next topic
Tightening up...
Thinking about dropping a few bills on some stuff to get me a stiffer, more responsive ride.
This is where I'm starting...suggestions?
Traction bars
Swaybar
You dont suppose the traction bars will harm streetability do you?
Tightening up...
I would think the traction bars aren't really needed yet.What is your current drivetrain setup?
Tightening up...
Che rear control arms and front poly bushings to start.
Turbo coupe sway bars front and rear.
That will clean it up quite a bit.
Tightening up...
My Front sway bar on the Sport (same as a TC) is bigger than my friends aftermarket sway bar.They can be had for cheap as well.
Tightening up...
Where would I locate TC swaybars though?  No time to junkyard dive atm.
Tightening up...
Welded in subframe connectors...
Tightening up...
No welder on hand mang, strictly bolt-on applications for the time being.  Also, don't you need to be putting down some serious power for those connectors to even matter?
Then again I'm asking this in the same thread I'm suggesting trac bars in :P
Tightening up...
I got these on my car, plus the quads going in.
http://www.cheperformance.com/CartGenie/prod-77.htm
these cars twist like pasta without SFCs on them. You can watch the space around the door openings change just jacking up the car the slightest bit.
Tightening up...
Quote from: Grumbles;263358
Don't waste your time with bolt-in SFC's. Find someone to weld them in if you don't have a welder.
Oh, and it's a Fox car...they [COLOR="Red"]ALL[/COLOR] need SFC's...period.
Tightening up...
Quote from: Chuck W;263367
Tightening up...
Mustang SFCs work just the same correct? I figure the underside is the same.
Tightening up...
SFC's it is then lol
Tightening up...
Quote from: 86XR7project;263393
No, they're different.
Tightening up...
Where do we get SFCs that work?
Tightening up...
Summit sells em for Tbirds
