Topic: Mustang Brake lines (Read 1133 times) previous topic - next topic
Mustang Brake lines
Does anyone know if Fox  cougar front brake lines are the same length as Fox Mustangs ? I mean the line that runs from the hard line to the caliper.
Mustang Brake lines
accoreding to coolcats.net,
"http://www.coolcats.net/tech/advanced/11inchbrake.html"
It says for the 11" front brake upgrade the mustang v-8 ones will work. I would assume any fox mustang with a v-6 or inline 4 or any other 1980-1988 fox tbird or cougar with 10" front brakes will work.
Mustang Brake lines
The Turbo Coupe and Mustang GT share the same lines,and are different from the V-6 and V-8 Birds/Cats.Just go to Autozone and pick up a couple of new ones.When it comes to brakes I don't take any chances using used lines.
Mustang Brake lines
And also make sure you use new banjo bolts...
I didn't on mine, and one broke.
Scary thing, at least I was on gravel less than a mile down the road from home.:hick:
