Topic: plastic fuel lines (Read 1348 times) previous topic - next topic
plastic fuel lines
snaped a plastic fuel line close to engine is there any kits u can buy to splice the line where it broke
plastic fuel lines
Yeah buy a hose and connect the busted pieces :D
plastic fuel lines
Not sure how you can splice it, but OEM plastic line is available here.
thnx a million
Thats what i was looking for .Just dont trust a rubber hose ans some clamps on a  preasure hose
plastic fuel lines
Barb fittings like these work very well for splicing the plastic fuel lines. You just heat up the fitting, and press the tubing on, let cool. :burnout: Fairly cheap at Homedepot, or Lowes.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
plastic fuel lines
What courgarman said. You can also find them at the parts stores in the HELP section.
plastic fuel lines
sounds real good thnx for the info
plastic fuel lines
parts store have a fuel line repair and you use a barb fitting to connect the two line together.
fuel lines
on the 88 TCs do those fuel lines have a plastic inner tube over the rubber line???  seems like they do because I can't the bottom duckbill fittings off!!!
