Topic: NOisey PS pump (Read 1163 times) previous topic - next topic
NOisey PS pump
My pump is so noisey, and is SO loud when turning, it is almost embarrassing to drive the car.
I sucked the fluid out of the pump and replaced it with lucas PS treatment.  It didnt help, maybe made it louder.
Anything else cheap I can try, I thought I saw a post on here about Honda PS fluid, but I cant find it now.
Any advise?
Anyone put a manual rack in a daily driver in one of these cars?
Mike
NOisey PS pump
Pump must be on its last leg.
NOisey PS pump
Its a pretty easy thing to do (replacing the pump) all you really need are some hand tools and a pulley puller, which you can rent at the autostore (well actually borrow, you pay like a 30 dollar deposit and get your money back when you return it), a refurbished pump (maybe 30 -35 bucks) and some fluid and your good to go.
FOXLESS!!
1994 Lincoln Mark VIII
NOisey PS pump
Swap to a new pump,and use Lucas fluid.Period.
NOisey PS pump
$50 for new pump, at least here. I pulled one hose out and ran the motor and turned the wheel till all the fluid came out.
NOisey PS pump
My steering pump is running quiet but steering is hard when cold and fluid is dirty.. What the best way to flush it?  Thinking about switching to Mobil 1 syn (mercon atf).. 97 cougar...New to the forum.
NOisey PS pump
I'd pull a line off of the rack and drain it that way.
