Topic: 460 rockers 1.7 in 302 for more duration??? (Read 2068 times) previous topic - next topic
Will this work i want to know for my next junkyard build!!!!
1999 Trailblazer(wifes rig)
i heard it works????
no.
the 3.8's have the same style of rockers as a stock 5.0. I am not sure if they would bolt up with no problems, but I would bet they could.
OVERALL DURATION will not be affected.
If you were to measure the durtion @ .050" and .200" you would notice a slight increase in duration at those--and all other intervals--where the valve is actually off the seat.
Increase in overall duration? NO
Increase in potential air intake/exhaust charge within the same given time range?  Yes.
Big block chevys and the 460 rockers will interchange, and so will the guide plates.
Just wanted more rocker ratio from 1.6 to 1.73 is the difference i think??? Im slapping a 5.0 ho together with new rings,bearings,ect out of my used parts and gonna throw some nos at it. So kinda piecen stuff together. Gonna port n polish some e-7s today for it.
Ten see how long she can handle and how much??? LOL
Here's an illustration of what I hopefully put into words before:
I have clevland pedestal mount rockers 1.73 they should be same as 460 correct. And overall is this work messing with???
