Topic: Name That Sender (Read 2088 times) previous topic - next topic
Name That Sender
bought a used 91
that was a project with some lose ends..this is one of them
it was just siting on the lower intake
Name That Sender
Intake air sensor.
Name That Sender
do i need it??
Name That Sender
yes
Name That Sender
Yep, though the ECU will go into "failure mode" and assume like 150F for the intake aircharge temperature all the time if you don't have one or it's failed.
Name That Sender
Just wonering but if the ACT sensor is just laying on the engine what is plugging the hole in the lower intake where it goes? :confused:
Name That Sender
probably another ACT
with it hanging there, its likely just barely changing resistance values enough for the eec to control fuel demand.
Pull codes and you might see fuel related Rich/lean issues.
per the diy link below.........
ACT sensor test ,,,feeds the computer
Resistance test pin to pin of the sensor (this is a variable resister proportional to temperature including outside air temp if the motor is cold)
at 50degF=58K ohms
at 65degF=40K ohms
at 180degF=3.6K ohms
at 220degF=1.8K ohms
Name That Sender
ACT has little effect on fuel demand - it just effects whether Adaptive Learning will be enabled (>100F) & some spark adjustments at high temps. ECT controls fueling exclusively during warmup etc.
Name That Sender
Quote from: Cougar5.0;263029
I am not sure why you say the above but its not correct.
The ACT has much to do with fuel mgmt as ref air temp changes.  The ECT is married up with the ACT in order to simply improve response time on data and provide the EEC with a more accurate input.
The ECT is more or less the second set of eyes out in the field for the boss (EEC) while the ACT is considered the primary input.
they both work together to manage fuel (maybe other things) with respect to engine air and coolant temps.
Simply saying the ACT has no roll after warm up reduces its purpose and tells everyone "i dont need that part"
Name That Sender
Quote from: jcassity;263049
You absolutely need the ACT if you want your engine to be able to adapt to different fuel and other variables like sensor drift over time.
I never once implied that you don't need it, I simply said that the ACT sensor is not used to determine fueling for warm up, when to go closed loop etc. - that's exclusively controlled by the ECT temperature. Now, Ford could have used the the ACT temperature as part of the calculation using the proportioning scalars below, but they chose not to.
As you can see below, in every case the proportioning factor is set such that ECT is used exclusively.
FRCBFT = 0.0000
FRCBFT - Fuel - Base Fuel ACT to ECT Proportional Mult
The ACT to ECT proportioning factor used to determine the fraction of
  ACT to ECT that will be used in the columns of the Base Fuel table FN1307.
  The resulting fraction will get passed to the scaling function FN022.
Formula:
[FRCBFT*ACT+(1-FRCBFT)*ECT]
FRCBFT of 0 indicates that table columns will be 100% ECT.
FRCBFT of 1 indicates that table columns will be 100% ACT.
Any FRCBFT value between 0 and 1 results in a value that represnets both ACT and ECT.
FRCBFT   =   0.0000
FRCSFT - Fuel - Startup Fuel ACT to ECT Proportional Mult
  ACT to ECT that will be used in the columns of the Statup Fuel table FN1306.
Formula:
[FRCSFT*ACT+(1-FRCSFT)*ECT]
FRCSFT of 0 indicates that table columns will be 100% ECT.
FRCSFT of 1 indicates that table columns will be 100% ACT.
Any FRCSFT value between 0 and 1 results in a value that represnets both ACT and ECT.
FRCTAE = 0.0000
FRCTAE - Accel Fuel ACT to ECT Proportional Mult
  ACT to ECT that will be used in the rows of the Accel Fuel table FN1303.
  The resulting fraction will get passed to the scaling function FN020B.
Formula:
[FRCTAE*ACT+(1-FRCTAE)*ECT]
FRCTAE of 0 indicates that table rows will be 100% ECT.
FRCTAE of 1 indicates that table rows will be 100% ACT.
Any FRCTAE value between 0 and 1 results in a value that represents both ACT and ECT
ALPHA   = 0.0000
ALPHA - Fuel - Transient Fuel ACT to ECT Proportional Mult
  ACT to ECT that will be used in the columns of the Transient Fuel tables FN1321 & FN1322.
Formula:
[ALPHA*ACT+(1-ALPHA)*ECT]
ALPHA of 0 indicates that table columns will be 100% ECT.
ALPHA of 1 indicates that table columns will be 100% ACT.
Any ALPHA value between 0 and 1 results in a value that represnets both ACT and ECT.
Name That Sender
dood,, your going to a level of detail that isnt needed.
You simply stated the ACT has very little to do with fuel demand.
the "revised" Emissions shop manual controdicts your statement.  Thats what I can spell out , nothing more , nothing less.
The Emissions shop manual simply says the act does xyz and the ECT fine tunes for performance.
Maybe your source is for later revisions of EEC tables?
Name That Sender
Quote from: jcassity;263146
Actually, it's contradicts, so you're not spelling it out very well. :shakeass:
Dunno about the Emissions manual, but I do know that he has a MAF 'cause I looked in the signature of the thunderjet person you responded to before posting, thus I used a A9X processor as an example. The detail was necessary since I helped develop the definition file for this processor and you said I was "wrong".
Name That Sender
yes, mass air would contradict everything i said.  Pegasus is probably the same so sorry for the bad post.  I didnt notice pegasus had a 95 either.
stock form makes the act work per the shop manual, modfied mass air would negate this.
Name That Sender
Quote from: Cougar5.0;263188
Uh I know what the ACT looks like/is for. I didn't ask the question [SIZE="3"]pegasus[/SIZE][/I][/B] did. I just wanted to know what was plugging the hole in his lower intake ;)
