Topic: Am I missing something? (Read 1535 times) previous topic - next topic
Because to me; this doesn't add up:
http://www.50tech.com/viewtopic.php?f=13&t=51531&p=54978&sid=47bc1e2a45e710e9371b781b9e6db5ad#p54978
i own a 87 dps lx built.. i have a intermit dead cyl effect every now and then. cars run very strong .. modds done are -- gt40x303 heads p&p,x303 cam 1.7rr,accufab 90mm ,adj fp reg, 255lph intank, lighting injectors, bypassed hego's,map,iac a/c..,under drives,140a alt,msd dist,frpp 9mm wires , ngk tr5, baster tfi coil, 6al, mac full lenghts, h-pipe no cats, dumped, mini spool 4.10, 11.5 slicks,products of power p&p upper/lower,solid mounts, and as far as i know a stock eec-iv . tremmec t5 king cobra clutch/pp. etc .. ********** problem ***** car is s/d
OK fair enough...Here's the kicker though:
thats the way the car was setup and tuned ( 493 rwhp)
Am I missing something?  Reading though that grammatical nightmare, I see no mention of forced induction or giggle juice.  The most optimistic N/A numbers I can find for those heads -- ON AN ENGINE DYNO WITH A HUMONGOUS CAM -- are 375 AT THE FLYWHEEL
http://www.hotrod.com/techarticles/engine/hrdp_0604_ford_302_engine_parts_failure/dyno_results.html
http://www.allfordmustang.com/forums/5-0l-talk/159861-so-i-went-dyno-today.html
https://www.fordmuscle.com/forums/1363123-post16.html
I even asked if I missed something, but I gotta be honest......I smell something that comes out of the back end of a bull.
Im sorry I didnt even bother to read through that list. I love it when people list stuff out in a practically stream-of-consciousness manner. :rolleyes:  Yep straight up moron right there. Next! lol
I wouldn't worry as he doesn't know what the hell he's doing (he is running a X cam in his car ;) )
Oh and what numb nuts runs that with a stock SD computer?
Paul, don't be so cynical. I installed a brass tipped rotor and dist cap on my otherwise stock 5.0 SO and wound up with 393 horses at the rear wheels :hick:
Quote from: Thunder Chicken;261995
OMGZ *heads out to advance auto*
Get a K&N filter while yer at it.
1987 TC
K!!!!!! I cant wait shes gonna haaauuull!!! :hick:
You're STILL 100 ponies shy of Skippy there :hick:
Seriously though, people actually come to car enthusiast forums with real issues and ask for help, but while doing so they have to lie about the power/parts they make/have and then wonder why the advice given was not spot on?  Honesty and correctness in situations such as this only help thise who are trying to help the person with the issue.
Lightning injectors? WTF does THAT mean?  I'm going to assume 24 pounders from an early Windsor motor equipped Lightning.  Those, stock rails and stock sized feed and return lines will sufficiently feed those magic parts that make almost 500 to the tires :rolleyes:
I think I'm gonna call his bluff when/if he responds.
he didnt say anything about the STREETGLOw stickers that add 30hp each..
No, no, no!
You guys have it all wrong...that 490-some HP is all from the "baster" tfi and the ngk tr5...
Whatever the fvck THAT is...
I was laughing over the "tremmec" T5.....that guy don't know shiznit about cars apparently. :flame:
Maybe he can make it work because he's "magic"!
