Topic: 5.0 EFI to Carb? (Read 1558 times) previous topic - next topic
5.0 EFI to Carb?
does anyone know how hard it is to change a 5.0 liter efi into a carbed engine?  do i have to change the computer or anything? thx
Re: 5.0 EFI to Carb?
I  think that it goes pretty much computerless. You would need a new upper intake obviously.
*Ahem* and a "lower" intake.  Carb setups only use the intake manifold and the carb.  Carb uses a one-piece intake as opposed to EFI's 2-piece.
Here's an article that will describe the process:
http://www.jason.fletcher.net/tech/efi-carb/efi-carb.htm
Do you have Sequential EFI? ('86+) or CFI that says "EFI" on the air cleaner (83'-'85)?  What year is your car.  If it's CFI, then here's the proper article:
http://www.jason.fletcher.net/tech/efi-carb/cfi-carb.htm
