Topic: need to know what color? (Read 1021 times) previous topic - next topic
i need to know what color the pices that go around the raido and cluster are so i can match them. i got ultra flat and it dose not match that good any one know what color dose mach so i can get it and repaint the pices i painted all ready?
 :punchballs:
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
some help would be nice like what piant to use. i cant seem to match the color for the inside trim
:birdsmily:
no one knows what color its called or where i can get the same color?
:birdsmily:
It's a dark gray with a gray,wood grain,or silvery gray squares.The outer prt can be painted any dark gray you desire.If you use an ultra flat,top it with a mist of gloss to give it a sheen,not a gloss covering.
I've never found a perfect out-of-the-can match for that dark grey. It may exist somewhere. You could always get a custom match and have it put in a spray can.
so all i have to is get a can of gloss and just mist it?
:birdsmily:
