Topic: Finally got picts of the 85 t-bird turboCoupe (Read 5442 times) previous topic - next topic
The "fan switch" is actually your engine coolant temp sensor, if that is not working properly, not only will it not allow your fans to run, but it will also make your car not run up to its potential. You may want to fix that.
SVO Capri, thanks, I have been driving the t-bird around the last few months without any real problems and has been a blast.  It does smoke a little on startup, I think the valve seals are shot and could probably use the head gone through.  I'll keep an eye out on you build, I would like to see what kind of power you get out of that 2.3 with those upgrades.  I have been to fordturbo.net and there is a lot of good info on there.
Tbird232ci, I have not replaced the temperature sensor but the gauge has always worked fine.  I use the jegs adjustable fan relay to control the fan now, but I might replace that sensor just to see if it works.
The ported and polished head swap is almost done. My ARP headstuds were late making it to Jacksonville so they didn't make it on the FedEx truck today. I should have it on the road tomorrow afternoon. Just in time to work out a few bugs and then it goes to the dyno Sat morning. Will post an update then.
On another note...yesterday afternoon (before head swap was started) a 2002 Mustang GT pulled up to me at a light and asked what I had in it. I was honest and told him a "2.3 litre, mid 12 second car", to which he said "cool". He tried me off of the light, and let's just say he was thoroughly embarrassed.
I don't really enjoy beating up on my Blue Oval Brothers, but this guy was the epitomy of DUMB ASS. lol
1985 Capri 75% SVO Mustang
2.3, T3, Ported lower, gutted, rotated, and extended upper intake, Ported head, Ported E6 exhaust manifold, 35# injectors, 65mm TB, 255lph Walbro, FMIC, Underdrive crank pulley, adjustable Racer Walsh cam gear, 24# of boost, full 3" exhaust, Flowmaster 40 series ler. SVO 3.73 Traction-Loc Disc brake rear, WC 5-speed, Hurst Shifter, Front coil-over conversion, Sub-frame connectors. 275-50R15 Nitto Drag Radials and Skinnies in the front. Still a work in progress.[SIGPIC][/SIGPIC]
Quote from: Rages6971;276372
Here is a couple update pictures of the T-Bird. I have it cleaned up, and the  mice got into EVERYTHING! I ended up pulling the dash and all the interior out and completely hosing the car out. Some how there was even a mouse nest in the heater box! The car still has a bit of a pinsol smell to it at the moment, but is way better then the alternative.
I am still having an issue with the electric fan. I replaced the relay, but it still isn't kicking on the fan. The wiring looks good, so I need to check the temperature sending unit. I might just switch over to the Jeg's adjustable temperature relay and be done with it.
I have a '92 F-150 waiting on your magic touch.  You sir, did an OUTSTANDING job on that car.  But, if you get a buffer, you can't use it.  I've seen your best work here, I think.  , that looks sharp.
:birdsmily:
Quote from: Old_Paint;294153
Thank you much sir!  I think there are benifets to rubbing a car out by hand, but I can tell you now my shoulders didn't appriciate it!  lol
I think a buffer on the large areas would have help and hand rubbed the tight areas.  I am getting better at my body work and product selection, and that's what I was trying to learn.
SVO Capri,
Some of the Blue Oval Brothers just don't get it, then again I would have a hard time believing it was a 12 second 2.3 also.  I know I killed a lot of factory 5.0's in my old turbo coupe, but it was no 12 second car.  The 2.3 turbo deserves respect, especially from the people that know how to work them over.  Keep up the good work!
Quote from: Rages6971;294479
I couldn't stand it any more. Seeing what you did to that red bird made me get after my truck.
Without further adieu, here's before ....
And this is at the end of the day today, after I did the chrome.
Can ya tell what that reflection is on the fender?
The kit I used was Turtle Wax Black Box. Made special for black vehicles, and so far, after step 1, I like the results. I still have Steps 2 and 3 to go. By the time I get to Step 3, if a fly tries to land on this thing, he's going wipe out. Step 1 is a polishing wax, and did it ever do some serious polishing. I haven't see this truck shine like this in AGES.
:birdsmily:
Quote from: Old_Paint;294482
And a  fine job you have done!  That looks like the reflection of a T-Bird tail light in the fender! :D  If that is just step 1, that truck is going to look as good as (if not better than) new by step 3.  It is a lot of work, but well worth it.  Your going to get compliments everywhere you take that truck, I love that black and silver paint scemes, and I haven't see an older ford f150 like that in that good of shape in a long time.
