Topic: column shift linkage adjustment (Read 1203 times) previous topic - next topic
What is the best way to adjust the column shift linkage in an AOD? I took apart the linkage only from the bracket that bolts to the frame, and when i went to set it back, it is shifting backwards. I set it manually in nuetral, with both linkage and column shifter in position, but when i go to shift the car it shifts from park to nuetral without moving the linkage, like its in drive. When i check underneath the car, the linkage is still in park. I dont understand this . It has got to be one of the most annoying things ive ever messed with. Has anybody got any ideas or ever had this happen to you?:punchballs: :punchballs: :punchballs: :punchballs: :punchballs:
FOXLESS!!
1994 Lincoln Mark VIII
It should be adjustable at the trans. Or you got a whole lot of play in the linkage somewhere.
Also make sure you didn't accidentally reverse the bracket when it was apart. ;)
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Well i got it so its driveable but i have no park yet, its one gear off. Im done messin with it for now.
The bracket wasnt all the way apart, just the two bolts on the frame.
Yea, that seems to be the problem. I had it right after i put on my headers/h-pipe, then it sounded like it was leaking at the collector so i took the linkage apart, tightened the  on the headers, and started with the linkage and now hit this snag. I do have a lot of play - the bushings are all worn out. Guess its times for some newbies.
FOXLESS!!
