Topic: Power steering blew out (Read 1134 times) previous topic - next topic
So I installed a new PS pump with the motor so I wouldn't have to do this. Well apparently the pump killed itself already and I need to swap it out. First, why would a new pump blow out with a new pump and high pressure line? It was installed correctly and worked fine for the last 1500 miles. It blew out after a quick throttle snap when going around a corner - I'm thinking the pump was bad to begin with as I had very poor/hard power steering at low rpm's (650) after installing the new pump.
Anyways, it's leaking at the same pace with or without the engine running. The reservoir went empty with the engine off in about 5 minutes. I think I need to pickup a new pump but not sure from where or what manufacturer - any ideas?
Edit:
It doesn't leak from either line - both the high pressure and low are dry - it leaks from somewhere on the pump itself.
1988 Thunderbird Sport
