Topic: need info!!! (Read 899 times) previous topic - next topic
need info!!!
alright guys, i have a couple parts and im trying to figure out if its worth putting them on or waiting,or if its even possible to use them.
i have an HO upper intake manifold with nothing on it,meaning i'll have to use my stock tb,and everything else,and 2 HO heads.
now my cougar-88xr7-302 SO motor,dosent have a maf sensor on the CAI,that makes me wonder, but it runs without a problem, and i believe its been bypassed by a previous owner.i wonder if this will cause problems when the motor is upgraded with the parts listed above, or if its even possible,or worth it.
i know the parts can be used, but i would like to know if they can be used without doing a complete HO  conversion?
also if the heads can be used,does it change the firing order?
302 baby ,yeah
need info!!!
Quote from: hocivic95;259056
[COLOR="Red"]The only parts "listed above" is an intake- yes it will bolt on. If you mean the HO heads are not on yet, not sure what you mean by HO heads. [/COLOR]
[COLOR="red"]The heads will work , they do not determine firing order.  Tha cam does that for you.[/COLOR]
need info!!!
the heads are not on, they are from a mustang gt.i figured the cam did but i wanted to make sure.
302 baby ,yeah
