Topic: idle valve (Read 801 times) previous topic - next topic
idle valve
where is it located under the hood? how do you clean it? original ford part-from a 1986 cougar xr-7 2.3l turbo 4 cyl 5 speed.codes clear-sometimes stalls when stopping- sometime it will stall when coming to highway tool plaza.otherwise idle is mostly true-about 1000rpm.
idle valve
what is meant by "codes-clear"?
if you have no codes, hten you always will have one code.
