Topic: Ac and smog pump delete... (Read 978 times) previous topic - next topic
i will be deleteing my ac and smog pump and was wondering if i had to buy that smog pump delete pulley??also do i just ask the autoparts guy for a shorter belt or is there another  car that has a smaller belt that will fit??? Thank you...
[/IMG]
Just enjoyin the ride!!!!
for the AC Delete, are you using the "Pulley" or are you using the Mustang Non-A/C Power steering relocation kit? If you are using the kit, you will need a mustang specific P/S Bracket.
You then just get a shorter belt.....measure it with some twine.
Even with the pulley kits likr the March A/C eliminator; you will need the Mustang P/S bracket.
ok cool ill order that stuff , its a good thing i need a new pump anyway, the old one leaks like a sive...
[/IMG]
