Topic: Doing a cam swap. (Read 813 times) previous topic - next topic
Doing a cam swap.
ok so I'm getting a racer walsh cam installed on friday. it has .415 lift. what kind of horsepower gains should i expect. along with the vc gasket and timing belt i am changing plugs, wires, cap and rotor. any recomendation's on what i should get for those. ive heard motorcraft everything but i was wondering if anyone had  used any other stuff?
[SIGPIC][/SIGPIC]1988 Turbo Coupe 19psi ,K&N Cone TurboBack 3in Exhaust , Ported Big Valve Head w/ Bo 1.5 , Stinger short throw
Doing a cam swap.
I run msd's but any of the low resistance wires didnt work right with stock ignition.  I run a crane HI-6R now and now it works correctly.  On stock ignition it ran like garbage misfiring just going down the road.  For stock ignition just get the motorcrafts.  you wont be sorry.  As far as the cam, cant say but it should move the powerband up, but you still have the IHI, so it wont help as much as you would think.  Search turboford.net for jon(mr. IHI).  He's gone about the fastest of anybody with an IHI.  I think hes running in the 12's or low 13's, but hes also running 24 psi and stage 2 or 3 boport cam and one of boports port jobs.  Also IHI's dont last long at 24psi because they seem to disintegrate everything aparently.  He's been through more than a few.
