Topic: lighted visor disassembly (Read 1606 times) previous topic - next topic
Anyone ever done it?
I've started tearing into one and I'm pretty sure I'm tearing it up in a non-recoverable manner.  At least not easily repaired.
__________________
Twin '85 TCs
White/ Grey 2-tone
That's a good question.I was wondering that myself a couple of weeks ago.
I've got the answer now.  Maybe the judicious application of glue will fix the damage done during exploratory surgery.
The unlighted visors have a fiberboard insert riveted to the bar.
The lighted visors are two pieces of plastic glued/fused together.  The lining is stuffed in the resulting seam.  The vanity mirror is removable by carefully prying at the lower edge at both corners.  The electrical contact also serves as the spring for the vanity 'lid'.
Remove the mirror, then the covering material can be removed.  If the plastic halves are separable, please let me know how to do it.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;258225
If the plastic haves are separable, please let me know how to do it.
Explain. I have swapped some stuff around on the visors but I am not exactly sure what halves you are talking about.
Pics.....
Nao!
Quote from: V8Demon;258511
Pics.....
Nao!
i second:ttiwwp:
Okay, will post info soon.
__________________
Twin '85 TCs
White/ Grey 2-tone
stripped nekkid visors
http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=18760&stc=1&d=1235775614
Top is lighted visor with vanity mirror removed.  The horizontal metal bar across the top serves as a spring for the lid and contact switch.  Three tabs along the bottom edge of the mirror lock it in place.  The visor itself is two pieces of plastic glued(?) together, trapping the mounting rod in place.
Bottom is an unlighted visor.  The mirror is stapled in place.
__________________
Twin '85 TCs
White/ Grey 2-tone
I hate to be a PITA, but you don't have any larger photos, do you?
I'd like to see the wiring...
The unlighted ones are just thick cardboard then?
I can email something to you.  (edit - let me try something first)
Fiberboard, similar to the door panel base.
__________________
Twin '85 TCs
White/ Grey 2-tone
Paul_Flockhart@hotmail.com
I can host it @ photobucket if you wish ;)
That works ;)
Thank you
If anyone is considering the Ranger OH console and has the longer style visor,  I think the only thing needed is to carefully remove the cloth cover from the tip, cut to the plastic to fit, then re-cover over the amputated area.
__________________
Twin '85 TCs
White/ Grey 2-tone
