Topic: Summit H pipe under $100 on ebay (Read 904 times) previous topic - next topic
Can't beat it for the price. I just wanted an aluminized off-road pipe to replace my catted H-pipe that had hollowed out cats in it, so I installed that Summit off-road H-pipe this fall. I plan on cutting some of the high cell density Magnaflow cats into it in the spring.
Quote from: Cougar5.0;258023
How do you like it? Im in need of one bad! Really tempted to click Buy It Now.....
Well I thought about it and I figured I couldnt pass it up. I need one so I can do my smog  delete (dont want to burn up the cats). All I could find were close to the same if not more and used. $108.90.... That a lot right now but I think it will be worth it. I am going to s my cats and sell some stuff and I will cover the cost.
Quote from: DVP;258024
I actually like the simplicity of the design. The pipes have minimal bends in them and the two-piece design allows a certain amount of flexibilty when aligning the pipes to the rest of the system.
If you look at the distance between the crossover and the ball-socket on each pipe, you'll notice that the passenger side is about 3-4" shorter than the drivers side. Depending on your flow-tube lengths, this could be an issue. I had to "stretch" the passenger side a bit to compensate.
Quote from: Cougar5.0;258034
Running stock Stang H now with Flowmaters lers and flowtubes. I would hope it all bolts up alright. I cant remember if the flowtubes are different lengths or not, its been a while.
