Topic: Junkyard, post needs. (Read 1903 times) previous topic - next topic
Well I'm going to the junkyard tomorow afternnon and thought I would see if anyone needs anything. I can't do anything big, but if you need anything small let me know. I'll be leaving around 8am and most likely can't check it after that. I'll try from my cell but let me know.
If you need stuff let me know, they are usually pretty reasonable. There are two automatic tc's, 2 87-88 v6 cars, and 2-3 83-86 v6's. One v8 car with hte motor and harness :( cut out.
Just thought I would see. Parts are in massachusetts, I won't be marking up. If im there I dont mind helping. You pay for the part, plus shipping.
I could use a xr-7 horn button, its the small one like a tc.
I know its small but worth a shot I guess. Its for a 83 Bird. Its a circular lense for the rear of the center console. If you were to fold the seat forward to get in it would light the floor area, there is one on each side of the console(also the same size as the glovebox light lense). It is probably just a bit bigger than a quarter. Its plastic and pops off with a few tabs. It isnt the same as the one in the center console storage box though.  Thanks let me know if you have any luck. Dan
NICE gray lighted sun visors.Nice console lid..After that,I'm good.
Alright I'm leaving. Vinnie, you may be in luck, I'll do my best to check on the other things.
i need the harness plug that plugs into the electric fan of a 99 up mustang gt.
~John~
If the TC's are 87-88, pull the two ECU's.  Let me know.
i need a gear shift indicator from a 83-84 tbird or cougar.
Vinnie,
No nice sunvisors. There were some in a  cougar, but they were faded and there was a tear in the drivers side. A decent pair of red, unlighted visors were there, but thats not what you wanted.
Dan, I have your lights. I took the lens cover and the plastic housing they pop into. I cut the wires behind where the lights plug in, so you should be able to swap them right in. They are small, shipping will most likey be under $5.
Shame,
The mustangs in the yard are older, nothing for you....sorry.
blackcougar71, I'm not sure what you meant, but I checked it via my ipod and say you wanted it. The only 83-84 cougar was a console with column shift car. I'm assuming you wanted the plastic piece over the floor shift. sorry.
no xr7 cars either..sorry.
I might have an XR7 horn button.  I stripped an '87 XR7 sometime ago.
1987 TC
Thanks for lookin'.
No problem. I had a decent console lid I sold a couple of months ago.
Quote from: HAVI;258000
If you find it let me know.
here is the link to the pictures of what i needed for my cougar.http://foxtbirdcougarforums.com/showthread.php?t=22136
