Topic: Electronic shift kit - AWESOME!! (Read 2946 times) previous topic - next topic
Anyone ever use one of these? I like it because you can switch shifting modes but was wondering if anybody knew if it was really worth the money?
http://www.jegs.com/i/B%26amp%3BM/130/70381/10002/-1
FOXLESS!!
1994 Lincoln Mark VIII
Probably not worth it.
Also no go with an AOD....
For Ford rear wheel drive and 4wd vehicles trans code D,E,P,U,H,L & V (found on plate on driver door post ) '97 Expedition/Navigator, '92-;97 pickup F-150, F-250, '94-'97 F-350, '94-'97 Mustang, Thunderbird & Cougar, '93-'97 Lincoln Mark VIII
Well its for the 94 bird....have to put the 20th on hold until i figure out what im gonna do with it....:mad:
FOXLESS!!
As a Bandaid I installed one on the '93 Grand Marquis AODE back in '98 when the transmission was slipping on the 1-2 shift(it only had 33K mi but was out of it's 3/36 warranty) ... Fixed it right up, didn't slip a bit and had a nice "thump" to the shifts... Only issue is it also gives hard down shifts... I cured that by putting a switch on the throttle body, which opened the circuit to the Shift Improver on closed throttle... The transmission lasted till about a year and a half ago, when it blew the front pump to housing gasket and began puking fluid at 131K mi...
Quote from: TurboCoupe50;257957
Do the AODEs have the same problem with the 1-2 accumulator spring that 4R70Ws do? That could have been the problem.
Quote from: thunderjet302;257962
Possibly, but it was a lot easier to install the Shift Improver than repair the servo...
How does it install? I didnt see anything on the website.
FOXLESS!!
You drove 100k miles in a year and a half? holly ! lol
Still wondering if anyone knows how to install/what it would plug into.
FOXLESS!!
Connects to a couple pins on the EEC... No I don't remember which two...
oh so its really just plug and play....cool
FOXLESS!!
where was the computer located? I cant seem to figure out where the wires connect to.
FOXLESS!!
Well finally got it today, right after i got home from work. Installed it, and it is F***ing awesome! i took the car for a *test drive*:burnout: afterwards, and from about a 30 mph start on the on-ramp to the highway, hit 75 in about 2 and a half seconds. It does, as Turbocoupe50 said before, have hard downshifts. I wish they made these for an AOD!
FOXLESS!!
They do, it's called a Trans-Go :hick:
Seriously, glad it worked out for you.  Obviously better than some of the other ones on the market I've seen installed first hand.
Tom, could you elaborate on this a little?  You've engaged my curiosity.
It's a lot different than any of the ones I've seen also, it has a toggle for three modes, normal, 1, and 2. Selecting 1 gives you a more firm upshift than stock and seems to shift a little higher in the rpm range, and selecting 2 takes it a bit further with the quick shifting and almost redlines in 1st and 2nd before it shifts ( on the package it said #2 was for racing and off - road purposes only), and you can also switch it back to normal mode. It was really worth the money, and performs better than i figured it would.
FOXLESS!!
