Topic: Burnt wire in trunk of 88 'Bird (Read 1017 times) previous topic - next topic
While installing new speakers in my trunk, I found a burnt red wire. It is located on the passenger side. Everything was working fine last time I drove it a couple days ago. Car has premium sound system w/Infinity after market speakers. Everything still works. The only thing I can find wrong is that the power switch on the EQ has given up but if you hold it EQ comes on. I had it repaired several years ago and never switched it off. Any ideas what this is for? I can repair and add a fuse but would still like to know what is for.
color wire?
also, trace the wire to the connector and there you might find a connector number / oem sticker.
Pics are just that and i cant make out the color or stripe.
