Topic: Exhaust H-pipe Fittment (Read 1644 times) previous topic - next topic
hey,
i was woundering if a 2 1/2 inch summit h-pipe for a 86-93 stang will fit on to the stock mustang 2 1/4 shorty headers.  or do i have to get the 2 1/2 h-pipe and put a reducer on it and if i have to do that will that mess up the length of the h-pipe to the ler tubes.
thanks again
jason
Re: Exhaust H-pipe Fittment
If the headers are off a stock stang then yes the h-pipe will work
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
so 2 1/4 collector off a 87 mustang header will fit to a 2 1/2 inch h pipe
99.9% sure it should fit - I'd try it. (there's always murphy's law).  I used a 2 1/2" Bassani X with stock mustang headers with no trouble.
If you notice the 2 1/2" is the pipe diameter, not the collector size, as the collector is flared, and is larger than 2.5". The mustang header is domed shaped to be able to mate with the h-pipe. That's what seals the exhaust, is the clamping force of the two pipes crushing together
192hp
What year stang is that header from?
192hp
