Topic: New goodies for my motor. (Read 4654 times) previous topic - next topic
Still need to get the lifters, ran out of cash.
Mmmmmm nice!  What cam did you get?
Oooo a CI cam. I bet it's going to run really good now :D
Niiiiiiiiiiice !!! I'll probably go with a custom ground cam when I start the new engine.My friend has access to a company that sells them for somewhere a little shy of $200.00.I'm proud for you Kitzy.
Great choice on going with a CI cam!
Thanks for posting up your cam card from Jay.  What I like about his information is:  Duration specs at 4 points not just at .50.  Spring pressure open and closed.  Cranking commpression.  Recommended shift points and maximum RPM.
Notice the negative overlap?
For those who will pull out a cam companies catalogue think to compare an OTS: don't bother, it won't have any where near the information for an accurate comparison.
Installing Jay's stuff is easy too, you don't have to hassel with a degree wheel to make sure it's installed propertly.  Just check lift at TDC.  I've put in three, all were spot on.
I see you went billet core as well.  I wouldn't go any other way!
When you get it running you'll pleased.
cool kitz.. good choice. I haven't ran mine yet so I can't brag about it but will be very soon :) good luck with your new combo!!
It's just the added things that I wanted to do do my cat for the winter, I have not accomplished any of it yet.
Whats holding you up Bob? I hope not the hood.
Nothing really holding me up parts wise. Just time, I still have to finish the one spring in the front and put the front brakes back together, bleed the system and thats it. Than order a scoop for the hood. I'm in no rush, sometime in March I'll be done
I doubt I will be finished by march, maybe the the day before cat jam.
Putting in the cam today. I got to get going.
cool man, wish I was home working on my car :( must be nice ;)
STILL haven't put mine in.... :toilet:
Quote from: V8Demon;266728
Still haven't driven my car :punchballs:
Any body looking for a E-cam? Springs next, then put the new cam in.I picked a bad weekend to do this outside rain for the next 2 days, so far holding off.
