Topic: Lincoln DOHC, what shoud i do with it? (Read 8833 times) previous topic - next topic
As the title says, I have a DOHC 4.6 and a t-45:burnout:  to do somthing with,
I was going to put it in my 94' tbird but the ol' gal is getting to worn out! I was thinking of using it in a future day to day driver, but what shoud the car be?
 87'/88' cougar?:evilgrin:
 another less worn mn12?
 83' to 88' tbird?
 The DOHC  4.6 would stay mostly stock i think, maybe exhaust and intake.
what do you guys think??
~1988 thunderbird~
In hibernation, waiting for spring.
more.
More..from the side
~1988 thunderbird~
well, theoretically id put it in a bird, if i were you.
~John~
mercury zephyr!
Would a modular engine even fit between the strut towers on a Fox? Those engines are ginormous when compared to a 5.0.
Quote from: jncocowboyx;255678
mercury zephyr!
:bowdown: :bowdown: :bowdown:
1978  2 door if it were up to me.
Yep, they would
and yeah they are huge. ant i think an old 4 door fairlane would be nice.
~John~
I kinda like the idea of a 97' tbird or a 88' cougar...The newer bird would have more creature comforts, but the t-45 swap would be more diffucult. and in general, MN12s are harder to work on...
~1988 thunderbird~
is it from a FWD continental?
if so, the bellhousing bolt pattern is different than a RWD block. meaning a custom bellhousing or adapter plate would be needed.
1979 Ford Fairmont
[/B]
Quote from: cougarcragar;255679
and, ummmm......
1979 Ford Fairmont
[/B]
Not really..88 ftmfw!
~John~
My vote is a 1981/82 Tbird.
1987 TC
Quote from: 32VFoxBird;255836
It's a 97' lincoln mark 8 4.6...I believe the block is refered to as a teksid block? I think it also has six bolt mains and "B" heads..so I'll have to use The stock IMRC plates for low end torque production..
~1988 thunderbird~
Quote from: HAVI;255924
Here in MI. a box bird would be hard to find in good shape. I've only ever seen them In local salvage yards..:( Today I came across a great deal on a 88' cougar with a 3.8 in white...It has a good bit of rust around the rear wheel openings. ONLY $300! I guy I work with owns it and drives it daily. I'm not shure about the rust though.  I think I could cut it all out and weld in new metal.
~1988 thunderbird~
personally i would just delete the imrc...
~John~
