Topic: wiring advice (Read 1151 times) previous topic - next topic
wiring advice
I want to wire some additional 12V electronics.  Where's a good place on the factory harness to tap into enough power to run the equivalent of 4-6 headrest LCD monitors?
something like this...
http://www.gooddeals18.com/product/PLVHR75M/PYLE_PLVHR75M_7_High_Resolution_Wide_Screen_TFTLCD_Headrest_Monitor.html
__________________
Twin '85 TCs
White/ Grey 2-tone
wiring advice
Nobody?
What I'm looking for is a KOER source in the trunk or rear seat area.  Any suggestions, or is that all in the dash?
__________________
Twin '85 TCs
White/ Grey 2-tone
wiring advice
you will probably have to find a source in your fuse box and run your own wiring to your desired place.  make sure to use a big enough wire to handle the load.
