Topic: 2.3 cam swap (Read 1801 times) previous topic - next topic
2.3 cam swap
I was wondering if anyone new what the max cam lift you can have before you have to start changing valve train stuff? I was thinking either the a racer walsh cam that has around .500 lift or if thats too much the ford racing a234 cam which is .420 lift. let me know what you think . Thanks
[SIGPIC][/SIGPIC]1988 Turbo Coupe 19psi ,K&N Cone TurboBack 3in Exhaust , Ported Big Valve Head w/ Bo 1.5 , Stinger short throw
2.3 cam swap
.500 will be fine with stock length valves but you need to get matching valve springs. You would be able to run stock valve srings with the ford cam.
2.3 cam swap
what is the most lift i can run without changing valve springs?
2.3 cam swap
I cant remember for sure but .500 is pushing it. When I had my ranger I put a Crane cam (.460in 480ex) and I used the matching springs. The cam and springs where under 300 buck but that was about four or five years ago. I still have the cam and springs if you're interested. Its pretty lopey and its a great turbo cam.
2.3 cam swap
Cam specs click link. It says valve float it at 6200 RPM but Ive turn it 7000 RPM with out float.
http://cranecams.com/?show=browseParts&lvl=2&prt=5&Vehicle_Type=Auto&Cylinders=4&Engine_Make=FORD&Year=1987&Engine_Size=2300%20C.C.&partNumber=190071&partType=camshaft[/URL]
2.3 cam swap
how much of a horsepower gain can i expect with a cam with .420 lift?
2.3 cam swap
Heres a cam that I will be running in the Ranger once I get everything all together for the swap. Its an Esslinger 2277, the specs are in here along with some more from them. Everyone that I've talked to seems to prefer the Essy 2277 cam over the FR a234 cam but to honest I havent tried Ford Racing one. Of course as with anything from Esslinger expect to pay alittle more.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
