Topic: mustang AOD, lentech feeler... (Read 2345 times) previous topic - next topic
i have a 93 mustang aod, shifter, and a complete 88 turbocoupe floor console  i want to put in my 88 tbird, i was told that the cable probally wont work? any ideas. I also have a turbocoupe shifter I can use.
88 thunderbird, 306 ,E7 heads ported by me, explorer intake, 70mm professional products TB, 8.8 3.73 rear is finally in. 11" front brake upgrade. still need some stuff
some nice weather to work on stuff would be nice ^^^
You need the shifter, cable, and bracket from a 83-88 T-bird or Cougar with a floor shifter and a AOD. AFAIK the Mustang parts won't work.
The Mustang cable will work if you use the Mustang shifter.As long as it's a matched set,you're good.I'm not sure the size difference,if any of the shifter  itself (the P-R-N-O-D-2) part.It could be made to work fairly easy I would imagine.
shifter, trans, and cable is all out of the same car. cable is still attached to tranny  , i set the console over the shifter and there is a very slight gap. thanks vinnie
I've been there.You're welcome.
Lentech valve body and 1 piece input shaft??
Lentech valve body and 1 piece input shaft?? thinking about this, talked to guy on the phone says the valve bodies are pretty simple to change. Anybody changed theirs?  :burnout:
I've swapped valve bodies a few times.It's not hard to do at all.Just pay attention,keep everything surgically clean,and you'll be fine.If you can do it before the tranny is installed,even better and easier.Lot's of bolts.I think they were 8 mm,but can't remember.Turn the tranny upside down,remove all the bolts that hold the valvebody to the tranny,unhook the spring clip thing that works the shifter detent,and there you go.Replace everything in the opposite order.Swap the converter while you're at it as well.Check the torque rating,I don't know what it is.I just snugged mine,but,the bolts really should be torqued correctly.The valvebody can be delicate.
sounds good, vinnie ur my new goto guy for info
Oh,be careful there.I just know about what I've done.I don't claim to be the "King of Tech".I'll let some other person have that job.There's only a handful of parts I haven't had to deal with building this car.If I can help,I'll be glad to.
lol thanks, i just meant that u usually answer my questions on here . :rollin:
Quote from: 88 thunderbird;255064
So who's the guy on the phone telling you this?
Glad to help.
Quote from: Kitz Kat;255095
a tranny guy that i deal with at work
